Hi, I’m playing with the demo version of Tinderbox. One of my first aims was to adjust the background color of the map view and the notes. I could manage that, even if a bit tricky to find the right place for that. Then I tried to set these settings for future documents. Each document I create shall start with the same custom style/look. And at that point I got stuck. If no note is selected and I set a color for background or text nothing happens. Pretty obvious, because in the inspector it’s written ‘0 notes’. Ok, it seems that in the inspector I can only alter selected notes. Under ‘Document Settings’ I only can alter the appearance of the existing document like map background and so on.
Then I found the ‘Document Inspector’ tab. Again it seems that I only can change the settings for an existing document. But there is a setting called ‘Default’. Hopes raising. But if I then set under ‘System’ tab the category to ‘TextFormat’ and the attribute to ‘TextBackgroundColor’ the default field is deactivated with a preset color hex and ‘(preference)’ written behind that. And now I don’t know in which direction my next step should go.
Again, I know where to change the appearance for existing notes, map view and so on. But I want to set this for ever in every newly created document.
Thanks in advance for your help
Best
Marco
