I’m back to trying out Tinderbox after a long absence. I find that I can’t delete a Column in Outline View. When the Column dialog is open and I hit the Delete button, nothing happens. Using TB 7.3.0
The column delete button works fine in v7.5.6. It seems the issue you describe was fixed in v7.3.1 - see here.
I see that now. If I end up using TB extensively again, I’ll upgrade. For now, deleting that column in the XML file solves this.
