But <font> tags went away in the last century (I remember first using them pre-CSS). A style ` would be more current HTML usage. Thus the above becomes:
The latter works in preview, even in a TBX with no export template. Better, IMO would be to add an HTML template that defines, in the head, a style block with CSS for different colours, etc., each as a CSS class. Now, with the blue text colour defined in CSS class ‘term_blue’, your stamp becomes:
The [C|c] matches an upper or lower-case character. The parentheses surrounding it set a back-references. This allows each match to preserve case.
In the replace term:
Because the HTML code needs to use double-quote, we use single quotes to define the replacement string.
Using back-references, the terms (e.g. $1) go outside the quoted parts of the replacement string otherwise they are treated as literal text (e.g. “$1”). thus the replacement string is composed of two quoted strings concatenated with a back-reference.
