Edit>Document settings…>Colors
Is it possible to change typefaces in the (nicely done!) color themes?
Thanks, R
Thanks, R
Yes, by editing the color theme (.tbc) files. You’ll find the build-in schemes in the package; you can add your own in the support folder’s color schemes folder.
Thank you! Forgive my ignorance - where do I find the .tbc files?
Select the Tinderbox application (or any application) in Finder, right-click, and choose “Show Package Contents.” The files you want are in Contents/Resources/color schemes.
And here: color schemes.zip (826.5 KB)
OK, only one more question, I think. I can’t open the .tbc file. What program do I use to do so?
Thanks
Never mind, I opened my text editor. Doh.
