Hi Kay,
Apologies, last got buried in inbox.
If I download this, click Test, and then Preview, I get:
/* PrismJS 1.16.0 https://prismjs.com/download.html#themes=prism&languages=markup+css+clike+javascript+applescript+markdown+python */ var _self="undefined"!=typeof window?window:"undefined"!=typeof WorkerGlobalScope&&self instanceof WorkerGlobalScope?self:{},Prism=function(g){var c=/\blang(?:uage)?-([\w-]+)\b/i,a=0,C={manual:g.Prism&&g.Prism.manual,disableWorkerMessageHandler:g.Prism&&g.Prism.disableWorkerMessageHandler,util:{encode:function(e){return e instanceof M?new M(e.type,C.util.encode(e.content),e.alias):Array.isArray(e)?e.map(C.util.encode):e.replace(/&/g,"&").replace(/e.length)return;if(!(k instanceof M)){if(f&&y!=a.length-1){if(c.lastIndex=v,!(x=c.exec(e)))break;for(var b=x.index+(h?x[1].length:0),w=x.index+x[0].length,A=y,P=v,O=a.length;A"+n.content+""},!g.document)return g.addEventListener&&(C.disableWorkerMessageHandler||g.addEventListener("message",function(e){var a=JSON.parse(e.data),n=a.language,t=a.code,r=a.immediateClose;g.postMessage(C.highlight(t,C.languages[n],n)),r&&g.close()},!1)),C;var e=document.currentScript||[].slice.call(document.getElementsByTagName("script")).pop();return e&&(C.filename=e.src,C.manual||e.hasAttribute("data-manual")||("loading"!==document.readyState?window.requestAnimationFrame?window.requestAnimationFrame(C.highlightAll):window.setTimeout(C.highlightAll,16):document.addEventListener("DOMContentLoaded",C.highlightAll))),C}(_self);"undefined"!=typeof module&&module.exports&&(module.exports=Prism),"undefined"!=typeof global&&(global.Prism=Prism); Prism.languages.markup={comment://,prolog:/<\?[\s\S]+?\?>/,doctype://i,cdata://i,tag:{pattern:/<\/?(?!\d)[^\s>\/=$<%]+(?:\s(?:\s*[^\s>\/=]+(?:\s*=\s*(?:"[^"]*"|'[^']*'|[^\s'">=]+(?=[\s>]))|(?=[\s/>])))+)?\s*\/?>/i,greedy:!0,inside:{tag:{pattern:/^<\/?[^\s>\/]+/i,inside:{punctuation:/^<\/?/,namespace:/^[^\s>\/:]+:/}},"attr-value":{pattern:/=\s*(?:"[^"]*"|'[^']*'|[^\s'">=]+)/i,inside:{punctuation:[/^=/,{pattern:/^(\s*)["']|["']$/,lookbehind:!0}]}},punctuation:/\/?>/,"attr-name":{pattern:/[^\s>\/]+/,inside:{namespace:/^[^\s>\/:]+:/}}}},entity:/&#?[\da-z]{1,8};/i},Prism.languages.markup.tag.inside["attr-value"].inside.entity=Prism.languages.markup.entity,Prism.hooks.add("wrap",function(a){"entity"===a.type&&(a.attributes.title=a.content.replace(/&/,"&"))}),Object.defineProperty(Prism.languages.markup.tag,"addInlined",{value:function(a,e){var s={};s["language-"+e]={pattern:/(^$)/i,lookbehind:!0,inside:Prism.languages[e]},s.cdata=/^$/i;var n={"included-cdata":{pattern://i,inside:s}};n["language-"+e]={pattern:/[\s\S]+/,inside:Prism.languages[e]};var i={};i[a]={pattern:RegExp("(<__[\\s\\S]*?>)(?:\\s*|[\\s\\S])*?(?=<\\/__>)".replace(/__/g,a),"i"),lookbehind:!0,greedy:!0,inside:n},Prism.languages.insertBefore("markup","cdata",i)}}),Prism.languages.xml=Prism.languages.extend("markup",{}),Prism.languages.html=Prism.languages.markup,Prism.languages.mathml=Prism.languages.markup,Prism.languages.svg=Prism.languages.markup; !function(s){var e=/("|')(?:\\(?:\r\n|[\s\S])|(?!\1)[^\\\r\n])*\1/;s.languages.css={comment:/\/\*[\s\S]*?\*\//,atrule:{pattern:/@[\w-]+?[\s\S]*?(?:;|(?=\s*\{))/i,inside:{rule:/@[\w-]+/}},url:RegExp("url\\((?:"+e.source+"|.*?)\\)","i"),selector:RegExp("[^{}\\s](?:[^{};\"']|"+e.source+")*?(?=\\s*\\{)"),string:{pattern:e,greedy:!0},property:/[-_a-z\xA0-\uFFFF][-\w\xA0-\uFFFF]*(?=\s*:)/i,important:/!important\b/i,function:/[-a-z0-9]+(?=\()/i,punctuation:/[(){};:,]/},s.languages.css.atrule.inside.rest=s.languages.css;var a=s.languages.markup;a&&(a.tag.addInlined("style","css"),s.languages.insertBefore("inside","attr-value",{"style-attr":{pattern:/\s*style=("|')(?:\\[\s\S]|(?!\1)[^\\])*\1/i,inside:{"attr-name":{pattern:/^\s*style/i,inside:a.tag.inside},punctuation:/^\s*=\s*['"]|['"]\s*$/,"attr-value":{pattern:/.+/i,inside:s.languages.css}},alias:"language-css"}},a.tag))}(Prism); Prism.languages.clike={comment:[{pattern:/(^|[^\\])\/\*[\s\S]*?(?:\*\/|$)/,lookbehind:!0},{pattern:/(^|[^\\:])\/\/.*/,lookbehind:!0,greedy:!0}],string:{pattern:/(["'])(?:\\(?:\r\n|[\s\S])|(?!\1)[^\\\r\n])*\1/,greedy:!0},"class-name":{pattern:/((?:\b(?:class|interface|extends|implements|trait|instanceof|new)\s+)|(?:catch\s+\())[\w.\\]+/i,lookbehind:!0,inside:{punctuation:/[.\\]/}},keyword:/\b(?:if|else|while|do|for|return|in|instanceof|function|new|try|throw|catch|finally|null|break|continue)\b/,boolean:/\b(?:true|false)\b/,function:/\w+(?=\()/,number:/\b0x[\da-f]+\b|(?:\b\d+\.?\d*|\B\.\d+)(?:e[+-]?\d+)?/i,operator:/--?|\+\+?|!=?=?|<=?|>=?|==?=?|&&?|\|\|?|\?|\*|\/|~|\^|%/,punctuation:/[{}[\];(),.:]/}; Prism.languages.javascript=Prism.languages.extend("clike",{"class-name":[Prism.languages.clike["class-name"],{pattern:/(^|[^$\w\xA0-\uFFFF])[_$A-Z\xA0-\uFFFF][$\w\xA0-\uFFFF]*(?=\.(?:prototype|constructor))/,lookbehind:!0}],keyword:[{pattern:/((?:^|})\s*)(?:catch|finally)\b/,lookbehind:!0},{pattern:/(^|[^.])\b(?:as|async(?=\s*(?:function\b|\(|[$\w\xA0-\uFFFF]|$))|await|break|case|class|const|continue|debugger|default|delete|do|else|enum|export|extends|for|from|function|get|if|implements|import|in|instanceof|interface|let|new|null|of|package|private|protected|public|return|set|static|super|switch|this|throw|try|typeof|undefined|var|void|while|with|yield)\b/,lookbehind:!0}],number:/\b(?:(?:0[xX][\dA-Fa-f]+|0[bB][01]+|0[oO][0-7]+)n?|\d+n|NaN|Infinity)\b|(?:\b\d+\.?\d*|\B\.\d+)(?:[Ee][+-]?\d+)?/,function:/[_$a-zA-Z\xA0-\uFFFF][$\w\xA0-\uFFFF]*(?=\s*(?:\.\s*(?:apply|bind|call)\s*)?\()/,operator:/-[-=]?|\+[+=]?|!=?=?|<>?>?=?|=(?:==?|>)?|&[&=]?|\|[|=]?|\*\*?=?|\/=?|~|\^=?|%=?|\?|\.{3}/}),Prism.languages.javascript["class-name"][0].pattern=/(\b(?:class|interface|extends|implements|instanceof|new)\s+)[\w.\\]+/,Prism.languages.insertBefore("javascript","keyword",{regex:{pattern:/((?:^|[^$\w\xA0-\uFFFF."'\])\s])\s*)\/(\[(?:[^\]\\\r\n]|\\.)*]|\\.|[^/\\\[\r\n])+\/[gimyus]{0,6}(?=\s*($|[\r\n,.;})\]]))/,lookbehind:!0,greedy:!0},"function-variable":{pattern:/[_$a-zA-Z\xA0-\uFFFF][$\w\xA0-\uFFFF]*(?=\s*[=:]\s*(?:async\s*)?(?:\bfunction\b|(?:\((?:[^()]|\([^()]*\))*\)|[_$a-zA-Z\xA0-\uFFFF][$\w\xA0-\uFFFF]*)\s*=>))/,alias:"function"},parameter:[{pattern:/(function(?:\s+[_$A-Za-z\xA0-\uFFFF][$\w\xA0-\uFFFF]*)?\s*\(\s*)(?!\s)(?:[^()]|\([^()]*\))+?(?=\s*\))/,lookbehind:!0,inside:Prism.languages.javascript},{pattern:/[_$a-z\xA0-\uFFFF][$\w\xA0-\uFFFF]*(?=\s*=>)/i,inside:Prism.languages.javascript},{pattern:/(\(\s*)(?!\s)(?:[^()]|\([^()]*\))+?(?=\s*\)\s*=>)/,lookbehind:!0,inside:Prism.languages.javascript},{pattern:/((?:\b|\s|^)(?!(?:as|async|await|break|case|catch|class|const|continue|debugger|default|delete|do|else|enum|export|extends|finally|for|from|function|get|if|implements|import|in|instanceof|interface|let|new|null|of|package|private|protected|public|return|set|static|super|switch|this|throw|try|typeof|undefined|var|void|while|with|yield)(?![$\w\xA0-\uFFFF]))(?:[_$A-Za-z\xA0-\uFFFF][$\w\xA0-\uFFFF]*\s*)\(\s*)(?!\s)(?:[^()]|\([^()]*\))+?(?=\s*\)\s*\{)/,lookbehind:!0,inside:Prism.languages.javascript}],constant:/\b[A-Z](?:[A-Z_]|\dx?)*\b/}),Prism.languages.insertBefore("javascript","string",{"template-string":{pattern:/`(?:\\[\s\S]|\${(?:[^{}]|{(?:[^{}]|{[^}]*})*})+}|[^\\`])*`/,greedy:!0,inside:{interpolation:{pattern:/\${(?:[^{}]|{(?:[^{}]|{[^}]*})*})+}/,inside:{"interpolation-punctuation":{pattern:/^\${|}$/,alias:"punctuation"},rest:Prism.languages.javascript}},string:/[\s\S]+/}}}),Prism.languages.markup&&Prism.languages.markup.tag.addInlined("script","javascript"),Prism.languages.js=Prism.languages.javascript; Prism.languages.applescript={comment:[/\(\*(?:\(\*[\s\S]*?\*\)|[\s\S])*?\*\)/,/--.+/,/#.+/],string:/"(?:\\.|[^"\\\r\n])*"/,number:/(?:\b\d+\.?\d*|\B\.\d+)(?:e-?\d+)?\b/i,operator:[/[&=ā ā¤ā„*+\-\/Ć·^]|[<>]=?/,/\b(?:(?:start|begin|end)s? with|(?:(?:does not|doesn't) contain|contains?)|(?:is|isn't|is not) (?:in|contained by)|(?:(?:is|isn't|is not) )?(?:greater|less) than(?: or equal)?(?: to)?|(?:(?:does not|doesn't) come|comes) (?:before|after)|(?:is|isn't|is not) equal(?: to)?|(?:(?:does not|doesn't) equal|equals|equal to|isn't|is not)|(?:a )?(?:ref(?: to)?|reference to)|(?:and|or|div|mod|as|not))\b/],keyword:/\b(?:about|above|after|against|apart from|around|aside
Weird thing is if I click on Test with preview already selected, it renders some of it OK briefly before reverting to outputting the raw code again.
Any ideas what Iām missing?
