Off the wall question, but is there a way to use Stamps to force a note to have its text format be Code?
Reasoning: As I’m learning and editing the code I’m finding that this is useful to view and to be able to test things out, play with new options. To accomplish this I create a Stamp that applies my agent porotype to new agents. I use this prototype to have $NoSpelling turned on, $SmartQuotes off, and $AgentQuery and $AgentAction visible. I can then easily copy and paste code between $Text and the agent query or action.
What I’d like now to do is be able to, through a stamp, is ensure the $Text format is Code, that way I can copy and paste code easier without its format getting messed up.
Although. you can set $Prototype="Code"; in a stamp, assuming you have already installed the Code prototype, it will not change the formatting of existing text or new text in a note to which the stamp is applied. I’ve always found it frustrating for that and other reasons to try to make an existing note into a Code note.
It is best to start with a new note. For example, install the Code prototype in a document, create a Code Notes container, whose on-add action is $Prototype="Code". Then create your code notes inside that container.
