I notice that Create Agent is disabled unless I have selected a note, in which case it works just fine. Is this intentional? Easy to select a note first, but not sure why I need to…
(in case it is relevant… just migrated to a new Mac, so plists, etc. could be an issue…)
Odd, I only reported this as an issue (elsewhere) an hour ago. As at v7.3.0, you can’t create a new agent is selected. These seems an unintended result and I’d suspect will be fixed ere long. But as I write, you care correct as to behaviour.
