DevonThink Label attribute
(Lyndon Drake) #1
Hi,
As far as I can tell, a drag-and-dropped DevonThink note doesn’t import the Label attribute (but it does, thankfully, import Tags). Is there any plan to import the Label attribute too? I noticed that someone asked about this last year, and wanted to check in case it has been implemented and I’m just looking in the wrong place in the attribute list.
Best regards,
Lyndon
(eastgate) #2
This will require some joint work with the DEVONthink folks; I’ve sent a query.
(Lyndon Drake) #3
Cool, thank you. I think it’s the only bit of metadata that doesn’t survive the journey across
