Hi all,
I often copy text from tinderbox to other code editors and find it annoying that two dashes “–” will be replaced to one dash “-” (so called “smart dashes”). I know I can change this in Edit/Substitutions for every note.
But is there any possibility to disable Smart Dashes for all notes in advance?
I don’t have that enabled in any Note. Not sure why I don’t and you do.
Interesting! In my case, it’s always enabled when I open a new TBX.
Thanks, Mark. I wasn’t aware of the Attribute $SmartQuotes
which indeed disables also the smart dashes.
So my only work-around would be to work with prototypes in which I set $SmartQuotes = False
Or is there a possibility to change the attribute value for the whole TBX document?
Yes. As with any System Attribute (except read-only ones) you can set a custom default at Document level using the System tab of the Document Inspector. However, with a few attributes that have preference-based settings, you can’t edit here…
… but instead you need to do this via the Document Settings (i.e. the document’s preferences). In this case you want Edit menu → Document Settings (Cmd+8) and then the Text and then set the ‘Smart Quotes’ control:
The default setting is ‘ticked’ which seeds the doc-level $SmartQuotes default value of true
. Untick the box to get your desired false
setting whereby Smart Quotes and Smart Dashes are disabled for all notes. For any notes where you’ve set $SmartQuotes locally you may want to re-enable inheritance.
If the inheritance aspect of attribute values is confusing, see my article on how inheritance works in Tinderbox.
