Export Key Attributes as Custom Meta-Data to Scrivener?
(Sturla Bakke) #1
Would it be possible to export key attributes in OPML, that, on dragging the OPML-file into the Binder, would be imported as Custom Meta-Data in Scrivener?
Thanks!
(Paul Walters) #2
I don’t know about the Scrivener side, but on the Tinderbox side you can add the built-in OPML template (File > Built-In Templates > OPML) then modify the OPML item template to include your user attributes. Just follow the pattern. For example the pattern
note="^value(attributeEncode($Text))^"
in that template can be copied and modified for your attributes
myattribute="^value(attributeEncode($MyAttribute))^"
(Sturla Bakke) #3
Thank you.
I didn’t get it to work on the Scrivener side, but that might be my limited Tinderbox-export-competence. I’ll fiddle with it some more, and report back.
