Pretty sure I’m just missing something here. What keystrokes allow the user to
Create a Note
Title the Note
Add content to the Note?
If I:
{return}
type the characters in the Title
{return}
type more characters
the last characters get placed in a search field.
If I use {escape} in place of the second {return}, the just-created Note gets deleted (afaict — it disappears).
Related: Is there a key-chord that changes the focus from the View pane to the Note pane (“Edit” pane? I’ve forgotten what the right-hand pane is called).
Thank you. I can see where that would smooth over the pane-hopping wrinkle.
For anyone following along, Split is described here in the Tinderbox Reference file. On my machine, the command is at “Note ▹ Split” and the key-chord is ⌃⌥⌘{return} .
