Get Info & Inspector pop-up locations
(John Miller) #1
Why does Get Info on a note bring that window up clear on the right side scroll bar? Shouldn’t it pop-up right at the selected note? Yes, it can be a tear-off but IMHO the initial location should be the selected note.
People may have more opinions on where the Inspector window pops up - it appears to remember its last location, which sounds fine on the face of it, but doesn’t work well with multiple monitors, if you’ve moved the TB window in the interim.
