Having Imported a CSV file from 2DO I wanted to change the sort order to _DueDate. This is easily done in the Outline View using the Sort Attribute. The Map View of course remains unchanged. But if you then Arrange-Cleaup- To Grid or To Column - the Map View re-arranges to the sort order identical to the Outline sort order. This is a really nice feature I had not discovered before.
