To reproduce this problem, use the Inspector’s Attribute Search for Quickstamp. Put in Caption into the search field and choose Caption from the list of values.
After some hunting, one finds Caption under General.
Intended functioning: when searching for the attribute, the result brings up the correct category. After that, the user can pick the correct attribute from the list in that category.
The same problem exists when using the search in Document Inspector, System attributes.
Interesting that the error does not occur with a parallel case such as searching for “Shadow”, which has related constructions such as “ShadowBlur”, “ShadowColor”, “ShadowDistance”.
Actually, I believe it is slightly different. As I understand it, the intent is when searching for an attribute bring up the correct result and that result is in the correct category. Search is supposed to be a one-step activity not “find category then find attribute”.
