Hi all: Within outline view, is there a keyboard shortcut for editing a note title? After you’ve created a note title and moved on to other things, is it possible to go back to the title and edit it from the keyboard, or is it always necessary to double-click on the note title in order to be able to edit it?
You can use option tab (⌥⇥) to navigate back to the outline, use the arrow keys to select the desired note, then shift-command-return to put the note into Rename mode (same as the Note > Rename menu command). If the outline has the focus you can use Find (⌘F) to search for a note by name.
Excellent. Thank you!
