I am entering lots of events. Some go on for days and months. Most take place on a single day. So I have set up a Prototype for Events with attributes including $StartDate and $EndDate.
How do I make the default $EndDate = $StartDate? This would mean that, for most events, I would only have to type the $StartDate.
Firstly, before possible nugatory work, why do you need an $EndDate? Tinderbox doesn’t need one for an event. I ask as if you want to find a zero length event it’s as easy to ask for one that has no $EndDate value set as it is to test whether start and end are the same date/time
If you really do need the $EndDate populated, I’d suggest an edict (disabled in the prototype itself - a boolean that doesn’t get inherited) with this code:
IOW, only work on notes with a start date set. If there is one and the end date has a default value (“never”) then set the end to the same as the start.
