No, maps are unbounded - they add more space as needed.
As regards a the parent container viewport, the controls you do have are:
$MapScrollX and $MapScrollY. These essentially set the view so the X andor Y map co-ordinates you set in those attributes are plotted at the X/Y centre of the parent viewport. Setting these also ‘fixes’ the child map in the viewport so you always see the same part of the map. They also where the map opens when zooming in from a container, i.e. drilling down a level.
$InteriorScale allows you to scale a container the viewport map but has no effect upon navigation.
When navigating up, the expectation is to return to “approximately their location when zooming into the container”. Things like smart adornments have no effect on where you end up.
On a blank bit of map? Try any of:
- Scroll. Sure,
- Zoom out manually ( ⌘±), use the View menu to do so.
Blind type (ideally the $name of a note). If there is a match, you’ll scroll to the first match.
- Use ⌘+⌃+⌥ to toggle the overview map.
If you want to know where you are on a map, right-click the map background and the top line of the context menu will show you your {X,Y} co-ordinates. If a note is selected, left-click the background to de-select it and then right-click.
If you can repeatably end up in the wrong 9i.e. blank’ space by all means upload a samll TBX showing the issue so others can try to reproduce and diagnose the cause.
HTH.
