Map vs. Outline Order
I thought that when you changed things in Map View it wasn’t supposed to change Outline Order.
I started with map view adding notes/adornments/containers to created my day planning system.
I then reordered my outline under separators, clarifying and simplifying what I had.
I then wanted to move my notes to new adornments according to this simplified plan. However, with every move I made from old adornment to a new, my outline kept having to be fixed.
I thought map and outline views are independent. What am I not understanding?
Thanks.
There is also a known issue - a fix under current test - whereby if you move >1 selected item, the result affects outline order. For now, move one map item at a time.
Thanks Paul and Mark. Moving a bunch on the map at once was the problem.
So only one at a time from now on.
…from now on, until 8.0.1
