Just got tinderbox a few days back. So a complete newbie.
I created a project called “Sales” which I want to cut/copy/move into my main project “Business Plan”. How do I do that without doing the entire things again?
I did something similar last night and was surprised to find that aliases didn’t carry over between documents. I had a doc that looked like:
my project
** original notes
*** note 1
*** note 2
** aliases
*** note 1
*** note 2
I copied the “my project” note and pasted it into a new doc. Every note carried over except for the aliases, which were gone. Are aliases expected to carry over or not?
(it just occurred to me that I could try selecting everything and copy/pasting the whole thing, instead of just copying the top-level note. I’ll report back once I’ve had a chance to try it)
I don’t think it’s documented, which implies its an un-envisaged edge case. As pasted notes get a new $ID when pasted in a different document, I guess the aliases lose their source reference. Of course, agent will generate new aliases (as pertinent to their query) but pasting retaining ‘manual’ aliases likely needs to be a new feature request at this point
If Tinderbox copied an alias to a new document that didn’t contain the original note, then the alias would have no original. In this case, note 1 might figure out that its intended original is the copy of note 1 that is also being moved to the new document, but in the general case this could be very tricky indeed.
