Hi Paul — thank you for helping me understand Tinderbox. Your text and links are valuable. Stumbling forward then …
Range of the container hierarchy in Tinderbox
The above illustrates what I’m asking about. The structure makes sense to me conceptually (the named content — by personal role — is immaterial to this discussion and is used just for illustration).
Opening a Tinderbox Document in the program Tinderbox is analogous to Focus Viewing a Note in a Document (a/k/a “hoisting”); you see and work with everything inside the container, whether the container is a Document or a Note. All of the top-level Notes in a Document are analogous to all of the Documents that Tinderbox can open. What I’m proposing is that this analogy be made workable. The result would be elegant, slick, and frictionless. The user could have separate Documents, but would be able, via expanding the Focused View all the way (a/k/a “un-hoisting”) the current Document, to have all Documents open with the full functionality of Tinderbox. This would overcome the limitation of having several Documents (the limitation is that with separate Documents global operations are limited to one Document), and make the question posed in this thread irrelevant.
Does it not make sense to extend the range of the container hierarchy in Tinderbox to include all Tinderbox Documents?
That’s why I asked for a chart comparing the properties of Notes (in particular, top-level Notes) and Documents. What is held at the Document level? Can it be moved up to the program level, or down to the top-level item level?
There is meaning inherent in hierarchy
But it’s not and there is. The content of the Note is determined by the user, as is the placement of that Note in the Tinderbox hierarchy. The placement of the Note in the hierarchy gives it meaning. Is it first? In the middle? Last? A child of another Note? A grand-child? Even in the (silly, but useful as a thought-experiment) case of a Document that has only top-level Notes, the order of the Notes (the flat hierarchy) gives each Note meaning that is independent of its content. Structure — any structure — creates meaning. We come to Tinderbox for the very purpose of creating meaningful structures.
… has meaning because the structure establishes a relationship between, for examples, “Grible” and “Pog”, and “Pog” and “Marther” and “Fromak”.
My other comments are off topic of “One Tinderbox document or several?”. I will post them separately.
—Kirby.
