Hi…
V7.1.0
There seems to be a difference in the way that QuickLinks and ‘Parked’ Text links are treated in map view.
QuickLinks are given a type untitled and they are visible in map view – but they don’t seem to be standard untitled links, because I can’t find a way to turn off visibility. Ie: toggling untitled link visibility in the Inspector will show/hide normal untitled links, but has no effect on the QuickLinks, which continue to show.
Standard Text Links created by using the parking mechanism are also given a type untitled (albeit they are coloured differently) — but they do respond to the visibility toggle.
I can’t find anything in the help file, this forum or abtref discussing this (it may be there, I just can’t find it). Is this expected behaviour and if so, is there a reason for the difference?
Thanks.
