Random Sorting in Outline
(Dirk Kalmbach) #1
Hi All,
is there a possibility to sort the notes within an Agent randomly? And if yes, can I do this regularly (e.g. within specific time intervals or with every opening of TBX?
Thanks
Dirk
(Mark Anderson) #2
There is no random sort setting. You might do something by using rand() to seed a Number type attribute with a value and sort on that. How often does this sort need to occur? Every agent cycle?
Also if you want a random pick of an item in the container look at the randomChild designator.
(Dirk Kalmbach) #3
randomChild would be appropriate for me - I wasn’t aware of this designator. Thanks for the tip, Mark.
Btw: on which coding language is TBX build on? I often struggle with the correct syntax - maybe knowing this would help me …
(Mark Anderson) #4
I don’t think it’s built on any particular language. Indeed, trying to think of it like a programming language probably just confuses. It is the result of some 18 years of incremental growth of what were originally a few internal macros.
(eastgate) #5
Tinderbox is written in C++ and Objective C.
The Tinderbox action language is hand-designed. It’s influenced by C, Lisp/FORTH, and by various other little languages. Despite appearances, it’s a very small and simple language.
There’s a nice list of designators in the Help chapter on actions.
