Renaming Attribute Values
Is there a way to rename an attribute value so that all notes assigned with that value show the renamed value?
Say, for example, I have a value, “tech” assigned to the attribute $Tags and I want to rename it to “technology”.
No but it is fairly simple to fix. Make an agent with query:
$Tags.contains("tech")
and this action:
$Tags = $Tags + "technical";
$Tags = $Tags - "tech";
You can even do it as one line:
$Tags = $Tags + "technical" - "tech";
This did the trick, thank you so much!
