So does that mean you expand a JPEG and store the full image data uncompressed? I’m just trying to gauge the situation.
Of course “snappy” is relative, in this case relative to the performance I normally enjoy when using Tinderbox on the same hardware. It is not too slow to be problematic, just slower than I’d expect for a file with few notes, but 9 large images.
Thanks Andreas, I appreciate the suggestion. I tried it with a test DT database and test Tinderbox file. It works exactly as you say, but it makes no difference to the resulting Tinderbox file size: it is still large. Plainly TB copies the image file from DT, which is what I expected, and then expands it and stores it uncompressed. I thought maybe coming from “outside” (i.e. DT) might lead to its being stored compressed.
Different design choices have trade-offs, this is one and it seems reasonable. I’ll just bear it in mind.
This is a statement from many years ago - can I ask whether Tinderbox has ever made the jump to reading Scrivener 3 files directly? It seems (from some experimentation) that the detour via export to Scrivener 2 is still necessary. Or did I miss something?
