Sense-making of Academic Literature Using Tinderbox
Has anyone figured out how to drag directly from Zotero to Tinderbox, as as to skip the step of needing to export to RIS and then manually dragging it in?
If I recall correctly, you can set the “drag” export format in Zotero to be RIS.
Yes, that worked. But then you can’t use the hotkeys to copy the citation or bibliography in another format. Guess I really need to figure out keyboard maestro.
Thanks.
I manage to get the correct title of the article but none of the attributes are filled. Any suggestions? I CMD-drag the reference, not the PDF.
Zotero
Edit: when the Text pane is moved further to the left all the information was visible :laughing:
