Setting a date attribute automatically
(Mariano Iannuzzi) #1
Hello, fellow TBXers,
I am trying to create a daily activity log in Tinderbox. I created a container where I store notes describing daily achievements.
I also added a User date attribute called $CompletionDate. I would like to have $CompletionDate set to “today” unless I manually specified a date.
I tried the following Rule:
If(!$CompletionDate){$CompletionDate=today};
However, the date is set to “never” rather than “today.”
Anyway, your help is most welcome.
Thanks!
Mariano
(Mark Anderson) #2
Is the ‘If’ above a typo? Action code is case sensitive. If I change ‘If’ to ‘if’ your code works for me. Slightly better usage - so as to get into good habits and not get bitten in more complex code - is to use date() when setting dates, even when using date designators. Thus:
if(!$CompletionDate){$CompletionDate=date("today")};
(Mariano Iannuzzi) #3
Thank you very much @mwra, bloody autocorrect :slight_smile:
It works! I did spend, nonetheless, several minutes scratching my head… :grimacing:
Thanks once more.
M
(Andreas Grimm) #4
@mwra For me this is not working since every minute the $CompletionDate gets updated e.g. it adds another minute to the date.
How can one stamp a CompletionDate that represents the minute of completion and then does not change anymore.
My Rule (!) looks like this:
if($Checked==true){$Badge=ok; $CompletionDate=date("today")} else {$Badge=calendar; $CompletionDate=never};
Can someone help on this?
Thanks
(Paul Walters) #5
If you want a one-time rule then modify your rule with $Rule=; as follows:
if($Checked==true){$Badge=ok; $CompletionDate=date("today");$Rule=;} else {$Badge=calendar; $CompletionDate=never};
This will wipe out the rule as soon as it runs once.
If you are going to use this in a lot of notes, then maybe consider using an Edict or a low-frequency Agent?
(Mark Anderson) #6
Or, change
To
$CompletionDate|=date("today");
See the logical OR operator. This code will run continuously but only set $CompletionDate once. That said, I think @PaulWalters answer above is probably as, if not more, practical.
(Andreas Grimm) #7
Just to the point, Maestro @PaulWalters. It works perfectly well for me. Thank you!
(Andreas Grimm) #8
Thank you @mwra. Works well, too. But just as you said, @PaulWalters’ suggestion might be the way to go in this very setting.
