This is easy. Create a document. Add a few notes. Add a built-in prototype (like “Task”). Follow @loosewire’s method to select all and change fonts. No matter if $DisplayedAttributesFont has a value or not, I’m not able to make the font-changing method affect $DisplayedAttributes.
Changing the font to Courier. Scratching my head! (Idea: if the built-in prototype had a $DisplayedAttributesFont, that would explain much. Are you using customized built-in attributes from the support folder?)
Ah, they do, and it does matter. It the font change (⌘T) is done without changing the font in $DisplayedAttributesFont in, for example, the Task prototype then the DA fonts do not change.
Got it.
