As I have grown as a tinderbox user, I now primarily use tinderbox as a text (mostly) repository, however this was not always the case. As I opened up some older tinderbox documents, I found one that had grown to 212 mb with several hundred notes.
Question: is there an attribute I can use to find and sort by my largest sized notes to begin the cleanup?
Many thanks Paul. That should help as I begin this project.
I suspect there may be notes that have images contained within the text that might be the culprit. Unfortunately, I feel I almost certainly I lobbed them into the rtf/text pane and not as a separate file attribute.
Question: Is there also an attribute to tell me which notes within the text field have images as well?
Thanks Mark. This was very helpful. I used the Attribute Browser and used $ImageCount as my first attribute. I then was able to begin looking at notes that contained at least one image.
