turns out you can add tags to your text as well, as long as you understand that the tags added by the template are still functional. So if I add a header tag here:
I’ve said it before: HTML Templates are the tragically underused superpower of Tinderbox. You think it’s the maps, and the maps are great, and the outline is great, but it’s the interaction with the output that makes this system so brilliant.
If nowhere else, the ‘rules’ about codes in Tinderbox (case-senstivity, whitespace, etc.), are documented here. If re-starting a deep dive into Tinderbox it’s probably worth taking a skim through the Objects & Concepts part of aTbref to see what’s changed from you remembrance from previous work.
Tinderbox’s general vibe (outside documented limitations such as above) is to be quite permissive - i.e. it will attempt to figure out the user’s intent - and fail silently[sic] if it can’t figure an outcome.
A superpower that is devilishly strange to the casual user. Like any kind of coding (although HTML is not really “coding”), find an interesting project to challenge yourself and practice, practice, practice. And keep W3schools.com open all the time in a browser.
A tip: for complex documents with numerous HTML templates, it is useful to use a code note for your CSS to make it modular and easier to maintain – say, a note named “myCSS”. In the <head/> of the template then insert
Thanks -aTbref is just invaluable. Believe me, I’ve been using it. This is just a tidbit I missed.
If we get together a list of ten or twenty most common syntax errors I’ll write a debugger. The frustration happens when there’s no feedback on a syntax error, and you lose hours. Doesn’t need to happen. I make syntax errors all the time in at least three other languages every day, and I don’t have to be smart: the compiler finds them.
