I tried to explode a note (test
in attached TBX file, v7.5.6).
The following selections are made in the Explode dialog box:
- Break at delimiter,
- remove title from text,
- delete delimiter.
The delimiter is ^\*\*
. Note the space at the end. The carrot is not necessary here, but it is useful when I have a note with triple-star sub-bullets under a two-star line.
Within the note are results from two serial attempts. The first attempt generates notes with undesired double-asterisk prefix. The second time is better, but puzzlingly leaves the last note with a double-asterisk prefix. The third time produced the same result as the second.
Does Explode usually require a warm-up run? And, what am I doing wrong with respect to the final item, which insists on keeping its prefix?
strange explosions.tbx (64.2 KB)
