Subtitles and shrink to fit
Folks, when a subtitle has been added to a pre-existing note, is there any way to avoid manually resizing the note to display the subtitle? I am finding that if I choose, say, “shrink to fit” to try and make both the $Name and the $Subtitle visible in the note in map view, only the $Name is visible.
Alternatively, if this is not possible, is there a way to make the $Subtitle value appear on the next line of the $Name in a smaller font?
As always, assistance will be much appreciated. Cheers, J
Nope! Sorry.
What you might do is to expand horizontally to fit, and make a Stamp that sets $Height to an appropriate value.
