I have included a Read me first file that explains the function of this little tbx example.
I put it up (with some dummy data inside) because I think it might be helpful for those just getting to grips with;
- Display Expressions
- Agents
- Use of the rule to set different badges
- On Add action to set prototypes
- Export templates to display different aspects of the same note
MeetingsTopicsTasks.tbx (112.3 KB)
Hope it helps
Very nice! I’m enjoying working through the example and reading your intro.
There’s a error – seems that something (a prototype most likely) is expecting to find a template in one location when in fact it is in another.
Also – general style is to put Prototypes and Templates as siblings at the root of a document (i.e., /Prototypes and /Templates. Nothing breaks if they are not, but the inbuilt prototypes and templates will create those locations if they are not found.
Thanks and thanks for spotting
I cut and pasted from my real file ( so as principally not to share the ennui of my meetings life with you all ) and missed it - The text template is just ^text^ of course - cheers
Yes it is. Though, export will not work as intended if Tinderbox cannot find the template, of course.
Just taken a look and yes I now see the templates container had become a child of the protocol container through a slip of the tab key - Whilst I always (when not slipping) have them as siblings I also always put them in a setup container ( containing others like boilerplate, css etc… ) as it gets them all out of the way with one click in outline view. - cheers
Here is a copy of @Markoconnor’s file that eliminates the error warnings by fixing the broken template links – nothing else is changed. Sorry to step in, but it’s helpful for some users to have files that do not throw off errors.
MeetingsTopicsTasks_pw.tbx (113.0 KB)
Thanks Paul - just beat me to it - These sort of slips are good for the learning curve anyhow
