TomD
(Tom Diaz)
1
How would I remove the first character from the name? For example: in using the explode note, I have some notes that have a single character.
Example:
#Name1
#Name2
#Name3
In this case: how would I remove the “#”
Want:
Name1
Name2
Name3
Thanks in advance
Tom
eastgate
(eastgate)
2
One approach might be, if your note delimiter is #, to check Delete Delimiter.
Or, you could set the Action in the Explode dialog to
. $Name=$Name.substr(1)
which means, “set the name to the part of the name after the first character.”
TomD
(Tom Diaz)
3
Thanks Mark.
Wow, after so many years, I had not noticed the delete deliminator option. Works great. Thanks for the code explanation as well, great extra tip.
Tom
