Not many changes.
I also fixed the doc as the existing page on AppleScript had no link to it.
I think it is worth noting that AppleScript is a bit exploratory at this point. A known issue is that although you can make a new attribute you can’t rename it, but if you do so manually via the Inspector is is a temporary workaround.
Dark Mode support is still bedding in.
As usual please do report typos, errors, boken/misplaced links and formatting errors.
