Won't create new note with ziplink
Ziplinks works fine if I have a note with a name.
It doesn’t work to create a new sibling note.
For example, in the note “Auditors” I type [[SEC]] but all I get is plain text and nothing happens.
Thanks
R
Using your description, I get this:
(v8.7.1 on macOS 10.14.6)
That’s what I’m aiming for but here’s what I get. I’ve tried several other documents, same thing. New document, same thing.
I make a note, I go to the text pane, I type [[text]], hit return, and nothing happens, just plain text.
OK, I downloaded a later version of Tinderbox 8, and now it’s working. Thanks much though.
R
