Dear Forum,
Many thanks for your help with my previous questions - sorry to be only asking things and not contributing (the time will come, I hope).
Ive much appreciated being able to use a text window with links to various commonly used Tabs (I like the text window because it stays in place when you click the link, so is a stable bit of landscape to work from, and I like linking to the Tag URL as it keeps the view (Map, Outline) that I want, which is not true if linking to a Note URL). It seems to work well, except that URL links for the âattribute browserâ Tabs get lost if the Tab is shut, or the program closed ie the URL is not persistent (I dont know if that is the computer speak for that idea). Im just checking that this is correct, ie the TAB URL for Map and Outline views will persist and recreate the view any time you click on it, even if the tab was shut, but not for the Attribute one. That would be OK, as the Attribute Tab can be stored in the tab Gallery, and that always works well (although cant be linked to with a URL).
- Its rather strange, but it seems as if currently all my TABS are being given the same name as one of the âattribute browserâ Tabs that i have opened. So, for example, I have an attribute browser showing all âongoingâ projects, where the search is called ongoing and hence the TAB is called ongoing. Every subsequent TAB that I open is also called Ongoing, even though it is, say, a Map view. And when I move the view from one container to another the TAB does not update. Any suggestions about how to reboot the TAB names so they reflect the reality?
I apologise if this is unclear, Im at the limits of my verbal dexterity to describe the situation. But any insights about either of those questions very gratefully received.
Best wishes
Thomas
