Adding a User Attribute to the $DisplayedAttributes via the Inspector destroys the DisplayedAttributes’s sort order.
Before:
After:
It gets really cumbersome if one keeps adding User Attributes (over time), meanwhile forgets about this behavior, runs into it again and then has to rebuild the desired sort order again. Even more so with notes that use a lot of DisplayedAttributes. I should know by now to don’t do it via Inspector but to add them manually instead, however I do it again and again via the Inspector
Not sure when this started and didn’t find something on the forum, however I’ve found a post by @mwra:
@eastgate is it possible that adding via the Inspector incorrectly uses a Set instead of a List? Anyway, could this please be changed?
