Is there anyway to auto save the tbx file every 2 minutes?
Thanks
Thanks
Tinderbox documents, like all macOS documents, are automatically saved from time to time. I don’t believe the interval is controllable, but it’s typically much less than two minutes — assuming that the document has been modified.
thank you
It is possible to turn autosave OFF. To do so, open System Preferences:General and check “Ask to keep changes when closing documents”.
If this option is checked, the document is ONLY saved when you manually save it.
