Is it possible to change the Colour of the connecting lines in Chart View. They are an insipid grey, I would like to be able to set a stronger colour if possible
Iām not aware of any settings that explicitly control the colour of the chart lines. Of course, āinsipidā is in the eye of the holder as itās a narrow margin between hard to see and too obvious.
Are you using dark or light OS mode? It sounds like youāve a possible feature request.
Thanks Mark - agreed insipid is in the eye of the beholder, I will try a different colour scheme - for reference Iām using light mode.
Sure. I wasnāt disparaging the idea, just pointing out that if find you still want control of that you can make always a suggestion for it.
Itās not currently settable, but that could change.
Honestly I think that would be useful, if you are using Chart view I think it would enhance legibility, particularly if you have ādenseā clusters of notes, helping distinguish where notes belong in that view.
Good afternoon, I think you should try different color schemes, this may be the solution to your problem. By the way, you can try to use this https://create.vista.com/colors/palettes/black-color-palette/ palette, Iām looking for color schemes for my projects here, since itās very convenient to use later and everything will be in the same style.
