In map view , I’ve multiple alias of a given note , is it possible to count but restrict the counting to particular map only ?
Let’s assume the note is ‘Note X’ and it, and two aliases of the note are all one map at path Some/Map
and 3 aliases elsewhere in the TBX. Thus the doc has one original of the note and a total of 5 aliases. But, we want the number of aliases in the map of Some/Map
and only aliases, so that we get a count of 2 items expect 2 items
A stamp:
$MyNumber = collect(find($Name=="Note X" & $IsAlias==true & $Container=="/Some/Map/"),$Path).count;
gives a count of 2.
Basically think through the discrete parts of the logic:
- the title of the note as this finds originals and or aliases (but also duplicate-named notes, so allow for that)
- do you want originals, or only aliases, or both
- What is/are the unique path(s) to the parent ($Container) of the items you want to match.
(Tested in v8.9.2)
HI Mark,
Thanks for the answer. Stamps makes it very clear. Having container and $IsAlias solves query.
If I may ask what purpose does $Path serve in the formula ?
Collect has to list an attribute value (the second input parameter) for each found note. I could have equally have used $ID. I wanted an attribute I knew to be a unique value. Though collect returns a list (i.e. un-duped) , I think it still useful to assume that each returned value in this context should be unique.
Indeed $ID would be better, as aliases in the same map with have the same $Path but different $ID values. I nice explanation for why $ID is needed as an attribute. An alias has the same $Name and potentially the same $Path as its original.
Aside, if using collect to find notes upon which to each, e.g. by using .each(){}
on the output list, then $Path is a good thing to collect.
Does that clarify things?
