The Hook to New script was missing from Hookmark’s Tinderbox 11 integration. Last night we added it, so anyone with a valid license will get the update for free. Or you can copy the Tinderbox 10 script manually from Hookmark’s Tinderbox 10 integration script to its Tinderbox 11 script (if Tinderbox 11 is not showing up, you can hit the “+” button at the bottom of the Script Editor window.
(Part of the Updates fees goes to paying a dev to keep Hookmark’s many integration scripts up to date. All this puts us in touch with many app devs, which is a lot of fun.)
(PS I’m the head of CogSci Apps Corp. that makes Hookmark.)
Thanks for the quick turnaround @lucb . I can’t seem to perform updates from within the app. Perhaps ought to post directly to your tech support, but bringing it up in case others have the same issue.
Message:“Update Error!
An error occurred in retrieving
update information. Please try
again later.
Cancel Update”
A suggestion for the integration scripts for Tinderbox - based on posts by much more knowledgeable people here than I: if you set the AppleScript to
tell application id “Cere”
instead of
tell application “Tinderbox 11”
Hookmark’s Tinderbox integration doesn’t break when the version number bumps. The application ID seems much more continuous than the application file name.
I get that this might be very useful for backstage/testing people, but for mere users like I, it would remove a point of friction every few years.
