Your problem isn’t with the loop! The problem is, what do you want to do inside the loop?
Let’s begin with a description in plain language. It might be something like this:
Remove all lines that begin with <img , and leave the rest.
That’s reasonable, but it rings a little alarm bell: we’re changing something ($Text) at the same time we’re walking through it. That can be OK, but you have to think carefully — just as, when sitting on a branch with a saw, the detail of the relative positions of yourself, the saw, and the tree trunk are suddenly important.
Another way to say this might be:
Make a copy of $Text, omitting lines that start with <img, and save the result in $Text.
function HTMLCleaner(){
var:string result;
$Text.eachLine(x) {
if(!x.beginsWith("<img ")) {
result = result+x+'\n';
$Text=result;
I’ve a simpler, if less elegant alternate that works without a loop. At a note at root called “log”. We’ll write to that just to avoid the saw/branch issue during testing.
The point of the regex re-cap and assumtions is to show how precise such an approach. For instance this would fail if a target line had more than one tag, e.g. the <div><img/></div>.
That’s why I think the loop solution is more elegant. I thought it too had a literality trap. This is because .beginsWith() operator only takes a literal input. So if an image tag line started with a space it might fail. It doesn’t! Happily it looks like .beginsWith()—and I assume .endsWith()—silently trim the tested string before testing.
In the light of this if you wanted to use the regex approach and were concerned about leading/trailing whitespace (including tabs and non-breaking spaces) you could go with this stamp:
Wow…why does it seem so obvious after you and MarkB demonstrate the code answer and explain what you did! Still not automatic for me yet. I am trying to write in pseudocode first…will also try flowcharting to see which I like.
I am going to work through more examples on my own. Thank you both for the wonderful explanations and different techniques!
One last question:
One thing I am just beginning to learn to do is to write my code line by line to see if each line of code works. Although tinderbox does not have a “breakpoint” marker like some code editors (not a criticism, rather just an observation), I notice you and MarkB are using $Text(log).
Is there a way I can use the operator create with $Text(/log) to make a pseudo break point to test line by line?
