This is correct, I spend more time figuring out what I need to figure out in TB.
Almost certainly if UML is a markup language like XML. Donât think in terms of one template per export. By using ^include()^ all sorts of things are possible.
One way to approach things is to take an existing UML documents source code and think how/where you would substitute data expected from XML.
Oddly, when I tried to look up the source code of a specimen UML file lots of references stated it had fallen from use.
Yes UML/RUP are out of favor. I brought it up because I am old and it was a structured system for analysis therefore rigid.
I think I see where you are going, a prototype will supply the primitives and the output (template w/ include) would be tied to those to build out the structure.
Linear thinking is so much easier when you donât want to think.
Back to the question,
The field/data elements could be a simple note with a field prototype - name, type, length, range, description in the body.
A table would be compose of fields plus additional data (name, desc, space).
Links can used for inner, outer, left, right joins.
A schema would be an upper level container containing all of the above plus name spaces etc. The alisase could be used to represent fkâs.
It sounds like a DTD, database docs and SQL could all be driven out of the above.
Sorry if I bored anyone, answering the question helps me think.
This approach would SQL in multiple RDMBSâs to be generated as needed. (postgres, MSSQL, the Big O).
This is easily done. There is nothing in TBX that requires a template to be HTML, the template (or a collection of them) can produce any output: CSV, TSV, JSON, XML, HTML, YAML, Markdown, LaTeX, RDF, Turtle, N-Triples, NDJSON, TOML, INI, TXT, RTF
John, thanks for the response. This is exactly what I wwas trying to get atâŚTinderbox can do most of what people need to do in a traditional RD model. To accomplish this they just have to look at the toolset and tackle the problem with these tools and forgoe wha ttheyâd traditinal see in a more rigid environment.
