I’ve just discovered Document Settings, and been messing around with the colours But now I’m stuck. I can’t find a setting to restore default colours (or colors)…Any suggestions? I’ve looked around with no luck. Thanks.
You simply re-apply a new colour scheme. For v8+ it is ‘Modern’, or if using OS Dark Mode it is ‘Dark Coral’. Admittedly, it’s more obvious once you grok how Tinderbox colours work.
See more here: Colors
ISTM that an “Apply Defaults” button on the settings screen wouldn’t go amiss (perhaps that’s a feature request for someone to make). IOW the button set the appropriate defaults for the Tinderbox version in use and the OS Light/Dark mode choice.
Thank you
