OK, several things here. Because you’ve not suppressed the rule in the prototype, where it’s not appropriate, it sets a prototype $FullName of ‘Person’. In turn, all notes using the prototype inherit a value of ‘Person’ which confuses the later test of the |=
operator.
However, even if the prototype rule is disabled (only in the prototype) that doesn’t quite solve the problem. Using a $FullNote assignment in either an OnAdd or a rule you get a different result depending on whether a note is dragged/pasted into the container (success), or is added new within the container (failure).
This appears to be a scheduling issue as the OnAdd/Rule actions are run before the user has completed typing the new notes $Name (or it does if you’re a slow typist like me). My hunch is these events should be queued until the initial naming of the new note is complete - i.e. title edit is closed. This last issue is probably what’s changed in v7.5 with the effects as reported above.
