Is there a way to use a note’s ID rahte than it’s name or path to call it out in action code, e.g.
inside($ID="1641503484")&$Prototype="pMedia")
. Clearly this is wrong, but I’m trying to find what is right. I have some fairly long note names, that might change. The $ID will not change, so I’d prefer to use that in agents and action code.
You can use the ID as if it were the name: inside(1641503484)
But this seldom a great idea; next year (or later today), will you know what 1641503484 means?
It might well be preferable to have a short, unique path name, and a longer and more variable display expression.
Alternately, consider referring to $MyString(/config/paths/someContainer), and put the container’s long and often-changing path there.
