Also, in the moment, ‘undo’ will undelete a note. Beyond that, walking back in the timeline there are current session last saved version (see menu File ▸ Revert To…). Then there is Time Machine or other back-up mechanisms.
Thanks, never used so far. Just made copies. Is there a setting or how often is it saved automatically?
I also have sometimes the issue that I unintentionally delete a container with notes. This happens in outline view when
moving container with notes around
or
selecting some notes (with Shift+Mouse-Click) in an expanded view
I cannot replicate it but it appears that a »uncoordinated« mouse movement form me causes the issue. If this happens Undo or Ctrl+Z doesn’t work. The container is gone and not part anymore of the current TBX document.
File ▸ Revert is, at present, less reliable than quitting Tinderbox and then using Time Machine to restore an earlier version.
I’m reasonably confident that it is not the case that moving a container around could delete the container, and am very confident that selecting notes with ⇧-click would not do so.
I can confirm this. The problem is on my side, the user and how I move the containers around. Since I changed back from a mouse pad to an ordinary mouse, it works better.
