Ability to filter columns in an outline
Don’t know if it’s possible or feasible, but is it possible to filter which columns are visible or not in an outline view using the query filter?
filter-outline-columns
Not at present. But both the filter and the columns are attributes of the Tab; if you want different settings, just duplicated the tab and change ’em.
