Dear Mr.Mark Anderson,
Thank you for your perennial assistance.
I am afraid that I will inform your aTbRef-8.tbx of graphical png file absence.
As follows :
Get Info pop-over
Roadmap pop-over
View menu
Window menu
All these web load the correct image and the images are there in the /images folder and correctly set up in the TBX. Might I suggest you try clearing your web browser cache so it loads fresh copies of the pages?
In checking this I did find the Get Info/repetitionarticle was pointing to an old image. I’ve updated that article so the correct image displays. I also found the image for the Map settings pop-upimage was missing and have fixed this too. The online ‘images.zip’ should be correct but out of caution and to reflect the edit to the Get Info/repetition article I have uploaded fresh copies of both images.zip and aTbRef8.zip.
I am afraid that I always clear my Web Browser cache evry week.
At this moment, I execute [opt+cmd+E] for Clear Cache in Safari.app.
Safari ver.13.1 under Mac OS Mojave 10.14.6.
Get Info pop-over.png, Roadmap pop-over are still invisible.
[2020/05/05 21:39:55]
Yours, WAKAMATSU Kunimitsu
Yours, WAKAMATSU kunimitsu
P.S
Exporting to HTML (aTbRef-8.tbx), index.html and images Folder are put in same position in Exporting Folder, is it correct ?
Apart from the home (index.html) and sitemap pages all the exported HTML is found in folder ‘index’. The images are are at the root of the site for consistent access. Plus, when I started this project, Tinderbox didn’t embed images. That is also why there is never more than a single image per note (for now!).
