Dear Mr.Mark Bernstein and Mr.Mark Anderson,
Thanks a lot for your detailed explanation.
It matters little that draw arc for Linkage.
I do not intend to cause you trouble.
Between Tinderbox 8.5.1 under OSX10.12.6 (Sierra) and
Tinderbox 8.5 under OSX14 (Mojave),there take a different one more tack,
as you can see in png file.
Between Tinderbox 8.5.1 under OSX10.12.6 (Sierra), after exporting to HTML,
blue bar graph remaining is left alone.
With Mojave, almost as soon as blow over after it’s exporting to HTML.
I would like to present this matter of behaviour to both for consideration.
Respectfully, WAKAMATSU kunimitsu
To summarise: using and older OS, macOS 10.12.6, the HTML export progress bar remains on screen after the process completes.
As this is a behaviour of the program itself, users here in the forum can’t fix it. So, such reports should be emailed direct to Tech Support (info@eastgate.com).
Dear Mr.Mark Anderson,
Point taken.
Yours, WAKAMATSU kunimitsu
No problem
